- Aug 22, 2012
- 4,115
I'm looking into making a tumbler reverse for my 9x20.
I'm sort of following the 9x20 LATHE TOP MOUNT REEVERSE TUMBLER by
Jeremy Taylor.
I'm considering making the shaft for the reverse gear (45t in Jeremy's plans) to fit the 42t gear but making the position adjustable for a 45t when I can find one as I may need the 42 for threading at some time.
If I had some brass I would make a bush for the centre of the gear but I dont so would the cast iron gear running on a steel shaft (polished smooth) be ok?
I will also be using a chunk of 6mm steel instead of 3/8 aluminium plate because I have a lot of it and it looks as if there is sufficient clearance so the large steel plate bolted to the head of the lathe doesnt need cutting, fingers crossed.
Thanks
Jeremy Taylor.
Thanks
