- Nov 14, 2016
- 3,007
People often fixate on materials thinking small lathes and mills can only work aluminum and brass. With a few exceptions that really isn't true, a decent small lathe or mill can turn many hard materials with care, just more slowly than a big machine.
Sherline and Taig both make nice small mills, but they are small. From what I've found a mill is more limited than a lathe when it comes to size a small lathe is mostly constrained by will it fit and does it have the power. Mills are much more limited by their rigidity. I have a Sherline mill and it is fine for little projects but rigidity usually becomes a challenge well before "it don't fit" does.
Really comes down to what you are going to do with it.
I have a Sherline 5400 3x12" mill (50lbs ish) and a Clausing 6x24" mill (700lbs ish). The Sherline does fine on the small model parts I bought it for, and I still use it for small parts. It has a higher rpm so works well with small drills and endmills so it complements the bigger mill. Drilling holes or milling small details it does just fine. Taking off lots of material or working on larger odd shaped parts was challenging, and it didn't take long before I started looking to add a bigger mill.
It is one of the few mills that you can legitimately pick up and put in a cupboard or under your work bench when it is not being used. I mean you could do the same with a 150-200lb mill but how many people will really do that more than once or twice.
There are a lot of options in between a Sherline and a Bridgeport, so knowing your limitations and needs will go a long way in helping determine what is right for you.
From a financial standpoint it is tough to beat a Bridgeport, there are tons of them out there so they are relatively cheap ($2000-4000 is not unusual). They weigh 1800-3500lbs so not a first choice for a shop in an upstairs bedroom. They are tall 7-8 feet which can also be an issue.
I like the size and capability of my Clausing so when these questions come up I lean towards the PM25 sized mills (727 728, PM30 etc), but I do like and use my Sherline so hate to discourage people from looking at them, just know what is realistic.
