- May 3, 2017
- 1,999
Hello, All.
I have a Powermatic band saw that had been modified quite a bit before I acquired it, so I'm not sure if what I need is original or not. The machine uses a pair of matching 4-step pulleys to regulate speed. One is a 3"-4"-5"-6" with a 3/4" center hole; the other is 3"-4"-5"-6" with a 5/8" center hole (both centers slotted for a keyway. The pulley used on the 3/4" shaft is damaged, and I can't locate a replacement. The undamaged 5/8" pulley has "Browning Maysville, KY." cast in it with "SCZ6" cast on the other side. The damaged pulley also has the "SCZ6" casting, but the part that may have had the "Browning..." is broken off. (See attached photo.)
Now to the questions:
1. Does anyone know where I might be able to find a 3"-4"-5"-6" pulley with a 3/4" center hole? I don't particularly care if it's a Browning, but that would be preferable. I've checked the usual places (eBay, MSC, McMaster-Carr) with no luck.
2. If I can't find a matching pulley, does it make sense to buy one that's close? I've located a 2-3-4-5, but would that work if I did not replace both pulleys? I recognize that the blade speed would be different because of the mismatch, but would that be critical and/or dangerous? (I also recognize that I will probably need a different V-belt, but that's no bid deal.)
Any help would be greatly appreciated.
Regards,
Terry
P.S.: I have no idea how the pulley was damaged. It was like that when I got, and I've just worked without that range. Turns out, it would be helpful to have it.
Regards,
Terry
