- Nov 9, 2018
- 377
This motor used to basically work when I got the lathe. But I cleaned every bit on this lathe, and re-wired the whole thing because wiring was all rotted.
Now the motor spins but buzz very badly.
What I’ve done:
What I’ve done:
- completely bypassed drum switch and wired motor direct to contractor according to diagram on motor
- Tested capacitor to ensure that it’s charging. Hooked up to ohmmeter, resistance gradually drops.
- Checked cap with multimeter, shows it as 600 micro F.
- disassembled motor and verified starter centrifugal switch contacts are free.
- Centrifugal switch seems to mechanically operate, and can clearly be heard engaging when motor slows down
- Verified motor is getting 240v
- Each motor winding shows about 1 ohm, or 2 ohms when both winding hooked up in series
- The motor looks essentially brand new.
- The rags on top of the motor are just there to temporarily keep a shaft from rubbing the motor housing.
