I bought a Tools 4 Cheap face plate for my lathe. A nice product but it had about .0165 runout on the face. I tried facing it with an 3/8" HSS tool. I used eyeball relief and rake angles in the "moderate" class. I found that the interrupted cut from the slots and holes caused the tool to chip or wear. The smooth centre portion turned quite nicely but once the slots started the tool was finished. Should this be a back gear project? Any advice on grinding angles? or tool material?
The face plate does not appear to be cast iron as it turned some rather longish curly chips and left no black crud on the ways.
I would really like to get this right before the face plate is only 1/4" thick ; ) Thanks in advance.
Al
Al
