John, side "b" is totally immaterial. When you sit the sine bar on a surface plate, for example, it may as well be infinitely long. What changes, as Wreck illustrated, is the distance from the bottom of the stationary roll to the roll that is elevated. In the plane represented by the surface plate in my illustration, the distance between the rolls "appears" to get shorter, the only option it has when you rotate it out of a plane parallel with the reference (surface plate or vise, or machine table, etc)BUT, the roll c-c stays the same, no matter what. That's the value you have to know to calculate the stack, which of course varies according to the angle. You can safely ignore the length of side "b".
