U
umahunter
Forum Guest
Register Today
If you are going to use the setup in your pic, position the indicator needle about 11 degrees (or less) off the horizontal so it will read correctly.
I just use a piece of bent rod and whatever ground block that's the right height to clear what's on the table. The longer the swing the more accurate the tram:
A NEW Brake Rotor may not be a good surface to reference off.
When I was working as a mechanic we ALWAYS resurfaced ALL New Rotors BEFORE installing them and when taking a touch cut for Zero reference they were almost always off.
You may want to have that surfaced before you use it and have them take a dial indicator to it and provide the actual run-out. There is a very good chance you will be surprised at the run-out.
ALL Brake Rotors MUST have run-out to function properly.
The run-out is what gently pushes the piston back to provide operational clearance for running. Without that the brake pads would be in constant contact with the rotor surface and drag creating problems.
