- Mar 25, 2013
- 4,620
You are doing it correctly by rotating an indicator in the spindle. That will work. Yes half the difference in readings.
Since your mill has a movable head on the Z as well as a spindle I was trying to make the theoretical point that a cylinder square could isolate these. That is probably overkill for your needs. I have seen some people use a large bearing race on the table and run the indicator on that to avoid the T slots. That seems like a great idea if you can find one in your travels.
RJ that is a clever solution to your off parallel table but seems like a real pain. How often does that problem occur on a quality machine like a Tormach? Did you consider getting the table ground flat?
Robert
Robert
