- Mar 10, 2012
- 224
This eliminates a ratchet or T-bar for engine and frame bolts. Saves some weight and space, both badly needed if your set the bike up for ADV travel.
Uses a 27mm Motion Pro tire iron/axle spanner to turn a 2" X 3/8" extension. The sockets are 10 & 13mm. You can use both ends of the extension with this setup.
Stuck in cyber misery- can't delete the copy attachment.
