- Dec 25, 2011
- 10,512
Chuck,
By "two vertical screws", do you mean two studs? And what do you mean by "half nuts"?
When you bought the later pintle type cross slide and upper compound swivel, did you get the compound slide with it? In either case, could you post the part numbers of the five or hopefully six parts? The newer parts that you bought should be 10-301, 10-302 and 9-303. I'm hoping that the original parts will be 9-301, 9-302 and 9-303. If you did get another compound slide, is there any difference between it and the original one?
I was a bit tired last night, and I misunderstood the question about the compound slide. It has the two vertical screws with half nuts to tighten them.
