- Nov 23, 2014
- 2,607
You have a pretty complete list. I didn't see Dykem but you have acetone for removing Dykem so assume it's on your list.
I use parallels on the mill quite a bit to get work above the vise jaws. Whole lot of options there: 1/8" thick, 1/4" thick, adjustable, wavy, thin, .etc. I don't have any 1/4" ones, but have the rest. I use the 1/8" most. Also have some Chinese angle blocks. You could do the same thing with a scribed line set parallel to the vise jaw.
Another thing could be a wiggler. There are lots of ways to align a prick-punched hole to the spindle. I have laser center finders, edge finders ground to a point, Blake co-ax indicator with a center finder attachment and a wiggler. Probably use the wiggler the most. I also use the wiggler on the lathe to center up a part in a 4-jaw chuck. Put the wiggler in the tail stock chuck, wiggler point in a prick punched hole. Put a dial indicator against the shaft of the wiggler and adjust the jaws until the indicator doesn't move.
I wipe away chips with a chip brush, wooden handle cheap paint brush. Have a 29 pc. set of screw machine length drill bits at the mills. They're nice as they are roughly the same length as end mills and edge finders so you're not cranking down on the table to get clearance.
Best advise is to pick up what you need once you need it.
Bruce
Bruce
