- Nov 27, 2012
- 7,857
My primary chucks for use on my mill are a 1/2" keyless chuck & a 14N, both with R8 arbors. The longer R8 arbors do not bother me. I do have a secondary 14N that I use for the mill with a 5/8" straight shank arbor (full length).
Some people like to shorten the straight shank arbor making it quicker/easier to change as mentioned. If you look inside a 1/2" collet there's only about 1.25" of contact area depending on the brand of collet. A genuine Jacobs 1/2" straight shank arbor can be cut in the middle relief area leaving about 1" contact area so the rest of the straight shank arbor is pretty much useless unless you use it to hang out from the spindle/collet nose. With R8 collets, the smaller the arbor is from true nominal size, the more the R8 collet will grip only towards the nose of the collet.
Another thing to consider & keep caution of. Jacobs Super Ball Bearing chucks are much heftier than other chucks in the same size range, mainly 14N chucks & larger. With a straight shank arbor on a 14N or larger, you should always take caution when loosening the drawbar on the mill. These chucks have some good weight to them, if your R8 collet did not lock in the taper, if you go to loosen the drawbar without holding the chuck in the other hand, the chuck can drop out of the collet causing damage to your vise, table, workpiece etc. I experienced this once, it wasn't on my own mill but I still felt terrible about it even though it was on a beat up BP, & learned my lesson. With a R8 arbor, this can not happen.
