- Jul 14, 2017
- 2,448
I've been needing an tool post grinder almost as long i've had the lathe and after not be able to found one to buy i've resulted to building one. The plan is to build one that i can mount in my tool holder and can adjust stone stick out as an tool cutter, this will allow me to do inside grinding and outside grinding with minimal stick out. For the motor i've chosen this old pressure washer motor to use, but the shaft is way to short to mount a pulley, so i've disassembled it and started with extending the shaft, i've done this process couple of times before and wanted to share how i'm doing it, in my next post.
