- Feb 14, 2014
- 28
Good Morning Folks,
So I have just got my new/used lathe cutting smoothly with a little help from some of the members here. I have a Standard Modern 16-60 lathe. Now that the machine is cutting well I am ready to buy a few more tool holders. Keep in mind I have a very limited experience with insert tooling and machining in general. I need help matching up inserts to tool holders that I can use with my existing tool post. Its labeled as a DTM100A. I don't know what standard that is, AXA BXA or whatever. Maybe the AXA but not sure no markings that directly match.
What I am needing is advice/ recommendations about insert types and holder that will fit my DTM 100A quick change tool post.
I would like to get:
An inner and outer threading tool that will hold inserts for different pitches, even acme threads. Maybe even inner grooves also?
An insert holder parting tool, not the rigid set depth, but the kind that will have adjustable depth. I saw some that work just like the HSS ones.
A recommendation for a boring bar and holder.
A knurling tool.
Now that the lathe is running I have several projects I would like to start learning on. I just need to aquire a few more tools.
Thanks for the look guys. All advice is appreciated.
Dan Reed
EDIT* Also I want to get a self aligning chuck. I have only a 4 jaw independent chuck at the moment. Is a 4 jaw self aligning better that a 3 jaw? I looked at some 6 jaw chucks and they are very expensive.
A knurling tool.
Dan Reed
