Tool Gloat !!!
You have a Marvin head in there too. Do you have the drive pulleys that go with it?
Yes the drive pulleys are there. The only thing that needs attention is the bell crank for the knee height adjustment and the handle for putting it in and out of the backgears is broken. Both are made from pot metal. The bell crank should be an easy fix with a replacement handle. The backgear shift lever will probably need to be made. I have some pieces that will definitely need to be posted to help identify what they are and how they are used.
