These are fabulous old machines. Much more rigid than today's lightweight castings and welded fabrications. The extra cast iron in the components, especially the bullwheels makes these machines smooth. Delta made a similar model in their 14" size with the gearbox for wood/metal, but it is not the machine that this Walker-Turner is. You will enjoy this machine every time you use it. Cheers, Geoff
Thanks for the good words in favor of the Walker Turner. They actually hit home with me...
Here's why. I am an avid woodworker as well as a HSM. That said, before I got the walker-Turner, I had a Craftsman 12" Bandsaw (wood only). This saw was problematic at first, but I fabricated new blade guides, and made a few other tweaks, etc and got it cutting very well.
Then, one day, when I was cutting up a cherry tree that got knocked down by a big oak during a storm, I found a rather large burl. Naturally that was spared from the firewood pile. But what to do with it?
It occurred to me, that if I fabricated a riser block and a longer blade guard for the Craftsman saw, I could saw and resaw the burl into usable figured lumber. I sized the riser block to be able to use standard 93 1/2" blades and ended up with a 13+ inch usable cut height. This idea worked out extremely well and I successfully got enough beautiful burl wood to make some inlays for an end table I made (that is actually a home theater servo subwoofer) and to make a hand dovetailed jewelry box for my daughter.
So, now I had a saw that could resaw wide stock as well as do regular bandsaw work (apart from metal). Granted, I have to disassemble the saw and install the riser block whenever I need the extra height and that is a nuisance.
I always had it in my head that one day I'd buy a bigger bandsaw that could do wood, metal and had the capacity for resawing without muss or fuss.
Enter the Walker-Turner... Number one the price was very right, number two it can cut metal by means of the gearbox, but the third item on my want list is lacking... I'm giving up the ability to resaw wide stock in favor of a much more rigid saw and the ability to cut metal. On the other hand, I got two out of my three wants and didn't spend $2000+ for a bandsaw.
So, you're probably asking why don't I just permanently install the riser block into the 12" and make it a dedicated resawing unit? Problem is, I'm out of room in the shop...
The Craftsman saw has got to go... I hate to sell it, because after the modifications to the blade guides, this saw works extremely well and I have a bunch of blades that fit it... But, someone somewhere is gonna get a nice little saw when I get around to putting it up on Craigslist...
That's why your words about the W-T hit home...
John
