- Apr 23, 2013
- 1,007
I think Rich has the best advice for starting out with the set from Amazon. And the size will work fine on your lathe. Just be sure to shim tools true centerline. I have no trouble hand grinding carbide or Hss tools. If you look at my avatar I hand ground the tools to form the balls inside the cube. The Amazon set also comes with the threading inserts and cutoff tool inserts. I'm an old guy that has been grinding tools for over 60 years.
Jimsehr
Jimsehr
