- Nov 22, 2010
- 371
I am making a test bar for my lathe that uses a I inch x 18" shaft that I wish to install two discs on that are about 3" in diameter and about an inch wide these parts are all aluminium
How much interference should I create between the hole in the disks and the shaft.
If I read machinrys book correctly I think the number is .008. Does this seem right?
My shaft is, presently 1.125 and the hole in my disks is. 1.004. I can turn the shaft down or bore the holes larger( turning the shaft down is the easiest for me). what is the proper interference ??
Thanks
Joe
Thanks
Joe
