- Jan 22, 2011
- 8,031
Ok...I own a Jeep with a 4.0l 6 that has the usual cracked exhaust manifold. So I decide it's not going to fix itself, nor pass inspection this time around. So I buy a nice ss header/manifold to replace it, and hoping it won't crack again any time soon.
Sounds like fun, eh? Well, I decided to check the mounting flange for flatness and to my surprise (not), found it to be a little out. Like 3/16", approximately, with a twist. In the old days, when I had my engine service equipment, about 2 minutes on the belt sander would flatten it acceptably. Done many, many heads and manifolds, in addition to various and sundry other less than flat surfaces. No longer having that machine, I can take it to a shop I know that has one, but another thought popped into mind. I'm sure the flange was plasma cut, and jigged up to weld all the tubes in place, and what I see is a combined result. Now it crossed my mind that the jig was probably ok, and this thing sprung or relaxed on the boat over here. Before I start carving or sanding on it, I begin to wonder if it will relieve itself somewhat at normal operating temperatures. Which makes me question doing anything prior to installing it. If that's going to happen, then fine, it will relax and be flat again. If not, I'm asking a lot of the bolts and gasket. But then again, if I make it flat now, and it relaxes, it's going OUT of flat and will bring in basically the same forces against the gasket and bolts. Soooo, I question what effect, if any, running it through a stress relief process will have. It is T304. I have not looked at the temperature curves yet to see what the critical temperature is. I can cook it in my propane grill, or I can send it to a heat treater. Or maybe bake it and then flatten it.
What say you, engine guys in particular?
