Titanium Tippe Tops
darkzero
Global Moderator
Staff member
Nov 27, 2012
7,858
Copy of a post from another forum, 8/2011
I've always wanted to make a Ti tippe top, a recent thread reminded me again. It was over 100 deg today, but I went at it anyways!:heat:
Well my first attempt is a failure! :gaah: :(
It looks nice, spins nice, but it won't tip over far enough to catch & spin on the post. :banghead:
The first post I made seemed to be too fat & heavy. When I spun it, the shaft would be perfectly parallel with the surface it's spinning on. So I decided to make a thinner post.
I also bored the recess in the ball deeper. The stock was 1" diameter. I originally bored the recess halfway in, 0.50". Saw a pic showing center of gravity should be below center show I bored it 0.125" deeper making 0.625".
Now when spinning the post drops down lower but still not low enough to catch the surface & flip the top over.
Success! :hurra:
Lightening the posts did the trick!
So I scaled down Chief-Yeah's measurements that he posted (thank you for those!). Mine was about 88% the size of his aluminum one & surprisingly my measurements weren't drastically off except the bore. My bore is smaller in diameter which I left as is. As Tony suspected, the wood measurements were considerably different when I compared the measurements.
Here's the very first post I made.
The second thinner post I made which I originally posted.
Here are the two posts after turning them down.
(I know, I know, extreme overhang but I didn't want to start from scratch & I managed to turn them down with out any cussing! ;))
The straight post is shorter than the other one & is harder to get a good spin on the top. More often it will spin pretty straight if I get a good spin. The slightly longer post with the larger diameter end is much easier to spin but rarely spins nice and vertical. As an experiment I found the steep point doesn't allow the top to lift up onto the post & spin. I would have though a smaller point would make it spin better.
But at least it is working!
I'll keep experimenting though, I think I will try a larger one & maybe some way to make it look cooler.
Others:
Carbidized then anodized.
Left: Satin Finish, Middle: Stonewashed Finish, Right: Carbidized Finish
WIP pics:
Prepared a 1"x1" piece of solid 6AL4V.
Drilling out the recess.
Bored to final diameter.
Drilling to tap threads.
Tapping the threads for the post.
That's done.
Time to make a mandrel which will also become the post.
Turning the ball.
After some some sanding.
Cleaned up the edge.
Making the second thinner post.
Great Ti posts DZ but...didn't you start your lathe on fire turning that stuff? :grin:
Haha, yeah I did have a small fire. Partly my fault for not paying full attention. Dull insert, forgot to add more lube, burning chip shot right out the bore of the tube I was making & ignited the chips it landed on. Scared the sheezo out of me, lessen learned. No major damage, just cosmetic on the gap, a couple coats of paint took care of it. I really should be using flood coolant but I don't want the mess.
Nice ball-turning attachment you have, homemade or purchased?
Mark S.
Both actually. At the time I did not own a mill so I couldn't make one. I bought one that was for a smaller lathe, like a Myford or something like that. I made a new base plate & riser for it. It's limited to about 1-3/8" diameter. I've been wanted to make a new one to allow larger diameters but I haven't had the need for it yet & the one have now works well.
I have it posted in post #9 here.
