Tire changer pad/cushion
rpatton
May 17, 2012
10
Noob to riding, only about 13 months riding and have replaced one tire, the second will be needed shortly. I figured out that I was going to go through a lot of tires so I went ahead and got me a tire changer from Harbor Freight with the motorcycle attachment.
After putting it together It looked like this part might mar or scratch the wheel if I didn't put something on it.
I decided that it was time to dust off the mini-mill (What can I say, I discovered that I should have started riding about 30 years ago so I've been doing some catching up this year)
I started with a piece of poly-something or other, don't know the exact material but it is just like the stuff they make cutting boards with.
Had to make the channel first then start milling away the excess.
I figure the fuzzy edges are from the speed of the cutter creating enough heat to cause the poly to start trying "weld".
Another view.
Now to take some off this other side.
Semi finished product, I'll sand the fuzzy stuff down some and maybe I'll round the edges with a router later.
From another angle.
And now a few views of the pad (cushion) "installed"
Only two more to make, I might try some other styles/designs later but need to get this ready to change a tire.
Nice job on the adapters. Very unique idea. Looks like it would work well. I use the same HF tire changer. Have done at least 10 sets of tires on mine. The stock changer from HF is terrible. I chopped mine down so it's lower and welded the motorcycle adapter to it. Also made some holders for tools on it. Got a nomar bar and a bead holder that won't scratch wheels. There was a guy on another forum making delrin adapters that I bought before I had a mill. Different design than yours but work well. Nice to see two people make two totally different solution to the same problem.
