- Feb 15, 2022
- 45
HI All,
I picked up a Criterion DBL-202 and DBL-103 in a local machine shop auction. I haven't used them yet, but I did take them both completely apart, cleaned them, and lubricated them with Vactra 2.
These are my first boring heads, so I'm not sure how tight the ways are supposed to be. Both move smoothly throughout their travel range, however the DBL-202 exhibits just a bit of tightness as the bar holder travels the 1/4" nearest to the 0 mark. Also, there is a small squeak in that range. I've lubricated the ways and the dial, but this continues. I've completely loosened the gib screws and also tried them with minor torque. Just looking at the ways, I can see that the ways on the body are slightly narrower at the dial end, when compared to the opposite end of the ways.
Is this normal? I wouldn't have thought about it except tha the DBL-103 does not exhibit this same tightness.
Also, what is a reasonable amount of backlash for a boring head? The DBL-103 has about 5 ticks and the DBL-202 has about 15. It would appear that backlash occurs as the dial wears in the two groves.
Thanks,
Andrew
Thanks,
Andrew
