- May 27, 2016
- 3,469
OK - I get from this that you are discovering the pressure by seeing how high it can push the water upwards.Miller lists 60PSI on several of their models with Procon pumps, and I suspect that's pretty standard since most seem to use the same basic pump setup.
I found a workaround once when I didn't have the right fittings to put a gauge on a cooler after reassembling the pump and it seemed to work well. I've flushed and then tested quite a few coolers now, and after I've flushed the system completely I like to fill it with fresh water, hook up a 5-6' output line and check the flow before adding coolant. I've found that they typically send the water 10-15' with the hose held just above horizontal. When I reassembled the pump I adjusted the relief valve until it sent the water 10-15' and it's been fine every since.
I thought 1 atmosphere (nearly 1 bar) was worth about 32ft.
Operating the pump with a bypass with a needle valve in it does let you adjust the pressure, but of course, the pump is maxed out all the time.
There are all sorts of YT videos of successful, even if sometimes crazy, setups. One Australian guy uses a low cost fuel pump. It really pushes a big flow. I had my doubts about continuous running performance, because fuel pumps normally operate intermittently once the fuel line is full.
So - at least some experimentation is gong to happen. I have ordered a little (low cost) radiator matrix normally used for a car heater. If it proves a bust, then it may have to be something more robust, like an oil cooler, but the simple 5 gallon bucket, as explained @benmychree does seem such a straightforward no fuss fix, it has to be attractive, and John used it for years!
