- Sep 22, 2010
- 7,223
How stupid can one man be? If it's me, sky's the limit.
I scribed two lines alongside the key opening, lined up the extended spindle gear for the handlever collet closer, and carefully tapped it on using a block of wood as a buffer and a plastic mallet.
Success!
Woops! NOT! I forgot this spindle retainer ring. Stupid, stupid, stupid.
Gear has to come off again. But how?
Used the puller with a bar of steel across the opening to brace the bolt. All that accomplished as to scar the gear with puller jaw marks along the edge (probably not harmful but stupid).
Help me please. How do I PROPERLY use this 3 jaw puller to remove the gear again, so I can put on the retainer O ring and then put the gear back on?
Thanks a million!
Nelson
Success!
Thanks a million!
Nelson
