- Feb 1, 2015
- 9,621
A 5/16-18 bolt will thread about 1-1/2 turns into an M8 1.25mm nut. An M8 1.25mm bolt will thread about 1 turn into a 5/16-18 nut.
When I got started with my g0602, I had a QCTP and adapter from LMS that resulted in a similar kind of setup. ... The way I dealt with it was to go out and buy a real Aloris tool post.
I used the M14 stud that came with my AXA QCTP and made a new Tee nut for my G0602.
Ok, looking at the manual, you don't have a slot for a tee nut. You would either need to use the adapter or drill and tap the compound for the AXA stud. If it were my lathe, I would opt for the second, assuming there is enough meat in the compound and with the understanding the I will have modified my lathe.
Yes, I can see from the G0602 manual that it has a tee nut that the tool post screws onto. This isn't on the G0516.
If I were going to drill/tap the compound for the AXA stud, I'd have to look at the compound's thickness to see if it seems meaty enough. As for modifying the lathe, usually when making changes to equipment I try to keep it to stuff I can undo. Though to be honest I can't really say why, because I never undo anything and virtually never sell gear.
3) Drill/tap two holes for the hold-down screws for the compound's feed screw. Doable, but since virtually all my work so far has been with aluminum, nontrivial.
While this is not the best video to recommend, its at least an example of someone doing the exact same thing you would need to do and will give you a better idea what it entails, it doesn't look difficult at all.
