T
Tom Griffin
Forum Guest
Register Today
Thanks. I need to get it put back before my dad discovers it's missing. :shush:
Tom
Tom
Thanks Tom, That was a good video. You partially answered one question I have had for a long time.
That is, when you are threading whether it be external or internal I have always wondered how deep the threading tool is being advanced using the compound. If one doesn't have the wire gages or a blade micrometer to measure and you are threading say 32 TPI you would need to figure out at what point you cease to advance the compound and do a clean up pass with the cross feed.
Would you mind elaborating on the formula again for root depth versus pitch
I just so happen to have to thread a few pieces. 3A 1.062 x 32 TPI both internal and external.
In the past I have relied on luck, using the cosine x the amount of advance of the compound, and a lot of trial fitting. (I was never really sure if I was doing this right or not)
Also, is the amount of movement on the compound at 1:1 or 2:1 like the cross feed.
I get so confused with this.
Thanks again, Vince
Can anybody please shade some light on the history or mathematical explanation of why some choose 29° or 29.5° compound setting for thread cutting or how it came so casually practiced?
By running in at something "just less" than 30* the main cutting is done on the left edge of the tool, leaving the right edge to clean up the thread flank with a very fine cutting action. This helps maintain a smooth surface on the, usually, main bearing surface of the thread.
Cheers Phil
Until it's satisfactorily explained I would just consider it a machinist myth.
You ask the question and then debunk the explanation with nothing but gibberish. Slow down and think again about the angle of approach given by using 29.5 * (or something just less than 30*)
So youre saying that pretty much ever since screw cutting lathes were invented, that the methods taught, and the educational literature printed for single point threading on a lathe is all complete guff?
