- Oct 31, 2016
- 2,645
I practiced threading on pvc pipe to start with. This was just to learn the motor skills in doing threading. Then progressed to steel. Depth of cut has a big effect on the finish of the threads. There seems to be some mystic, almost like bragging, on how large of a depth of cut you make in any type of machining. I can see in a production shop where depth of cut is important. But in a home shop there is no prize for how fast you can machine something.
When I cut threads I start off with light cuts. Then heavier cuts. Then back to light cuts to finish the thread. How coarse or fine the thread is also has some bearing on the depth of cut. Very fine threads require a pretty small depth of cut.
Practice, practice and more practice helps to get better results.
