- Dec 3, 2021
- 20
I currently own a low hours but 35 year old 1.5hp Jet JVM 830 Milling machine. Its badged as an MSC model from where it was bought in the mid 1980's but I
was told its basically a Jet JVM830F
It was bought by a relative who did some hobby machine work and farm maintenance with it and several other machines.
I've had ownership of the location and the equipment for 20 or so years now and have used it very sparingly myself.
Its main use has been for the occasional fly cutting job, some light fabrication, and mostly just as a heavy duty drill press.
I'm told it weighs in at or just over a half ton. (The original shipping weight on the pallet and crate was 1204 lbs total shipping weight.
The crate and shipping materials and iron brackets were likely close to 100lbs.
I'm approaching retirement age and no longer plan to maintain that location and the plan is to sell the place in a few years.
I've been knocking around either selling the mill and just buying something smaller, or to move it to my home basement.
I can move the machine from its current location easy enough, its getting it down the narrow wooden stairs into my 75 year old house.
I've hauled large items up and down the steps before and have reinforced the under supports of the stairs. I just removed a 400 lb freezer from the basement,
which took two guys and a handtruck. That likely put 1,000 lbs on the steps since I and my helper both weigh over 300lbs, plus the 75" tall commercial freezer and Harper hand truck. Weight on the steps shouldn't be an issue.
The plan would be to remove the motor, then the upper turret section as a whole, then to remove the handles and the table.
That leaves me with the Z axis slide assembly and the main body of the machine.
Has anyone ever moved one of these types of mills or disassembled one for such a move?
I have the original papers for the machine, and have had the table off before, but removing the lower section is a bit more involved.
I'm mainly wondering what the base casting weighs with and without the lower Z axis lift assembly?
I'm thinking that the cast iron framed motor is likely around 90 lbs, with its mount and cast iron pulley attached, the upper turret assembly looks like about 200 to 225lbs or so complete with the belt cover in place, and the table, which is 9x36", is likely between 125 and 160 lbs or so if you include the screw and handles.
The lower lift assembly is likely as heavy as the whole table itself, its a rather thick chunk of cast iron and is likely in the 150-175lb range.
These weights are all a guess just by looking at it as it sits.
I do know that I cannot budge the thing where it sits. No amount of pushing or lifting by hand moves it so much as a fraction of an inch and its not bolted down.
The casting doesn't seem all that thick but it is cast iron. Its currently sitting on leveling pads, which will also get removed.
I'm also thinking about putting it on a platform once reassembled in my basement to gain a bit of working height.
My basement has 7ft 4in ceilings and a solid concrete floor. The top of the machine on its current rubber machine pads is 74".
I'd like to see another 4in of height for ease of use for a guy my size, but its not an absolute requirement and can be done anytime.
I have rigging gear, winches, rollers, a 1 ton truck and heavy trailer, so moving it is no big deal, its just going require finding a volunteer to help.
I figure if so long as I can get it down to less than 400 lbs, its doable. Getting the weight down to under 300 would be even better but I think I'd rather
take less apart than to deal with having to reassemble things that didn't need to come apart.
I am thinking though that if I do remove the lower lift assembly, I'll likely be able to do the whole move alone, at my own pace and not in any sort of rush.
There's also two small Craftsman lathes, one a 12-36 (Atlas 3000 re-badge). which I definitely will be keeping. We determined that it was a 1959 model that I myself first assembled in 1988 and used only for personal use since new. Its on a full cabinet. I'm thinking its not much over 300 lbs complete. I can lift the motor end off the ground by simply grabbing the edges of the cabinet and I'm not the picture of fitness at my age.
I did consider selling the mill and going one of two ways, either keep one of the larger mills, and go through the needed work to locate one of those into the basement, or sell this one too and just find a table top model that's easier to move or a larger drill press which in many ways makes more sense in some ways.
The important piece to me is the 12-36 lathe, I have plenty of use for that, but the mill isn't a requirement. maybe it would be if it were more readily at hand in the basement though.
I'm a bit torn between keeping it and giving up the space permanently in the basement, or to sell it and put something I'll use more often in its place.
From what I see these selling for I don't see it worth me selling it.
Either way, come the end of 2022, it will be moved or sold to allow me to eliminate the long drive to where its located now.
I also can't say I'm looking forward to moving the mill down a flight of steps though.
