- Jun 22, 2023
- 356
I would assume that you kept track of the vendor to not buy from then in the future? if you use e-bay or amazon you have free returns and you can make them correct the issue. i also assumed that you payed a lot less than it would cost from a local higher quality provider?Not that I need wun, but iz there a hi quality mini lathe manufacturer?
I'v had sum junk. Got a chuck backing plate from India that seemed to be made uv a cottage cheeze scrap metal alloy. (a backing plate iz wut you uze to mount a chuck to any particular lathe) It wuz a waste uv time machining it kuz it deformed and crumbled wen I first tried to put it on the machine.
Sumwun gave me a drill press that wuz made uv the same stuff, so the table broke off. I tried to salvaje the motor, but the wiring came out from deep in the stator winding.
the point I'm making is that on this cheap stuff you are the QC team, is it worth it? that is up to you to decide but at the end of the day some of us have proved that good value can be had from these low cost sources. You do need to enter into the transaction with your eyes open.
my moto is "you very rarely get more than you payed for but you will often get less"
