- Nov 14, 2016
- 3,006
Even on published specs, Q/C varies wildly within a certain bracket of pricing.
Lower cost machines within that variable price bracket for the same type machine usually having lower Q/C.
I've noticed, looking at different vendors for the same machine, you can find some variation in dimensions and weight. The ones I listed were from Little Machine Shop, Micro Mark gives their 7x16" as 38" long, 12" deep and 12.75" tall and 86lbs...
I try to go by published specs for comparisons since I don't have an example of every lathe to measure. Just have to trust the accuracy / honesty of the vendors.
Interesting that with the lathe in front of you Micro Mark comes in almost as far over as LMS comes in under your measurements. I bet LMS measured the lathe as it comes out of the box (tail stock tucked in, handles off etc), while Micro Mark is measuring with the lathe set up and tail stock at full extension.
A little narrower, but almost the same working area as my 9x20. While they have their own set of issues, the 9x20s really are a nice option for the space constrained and similar price to the higher end 7x lathes. Of course 250lbs so better bring a friend or two to move it into the shop.
