- Jun 8, 2016
- 603
Found a 13x36 Clausing Colchester lathe locally. Asking price is $1300.
From the ad:
Clausing Colchester 13x36 Gearhead engine lathe
It has a 6" 3 jaw chuck, Collet Closer, Square indexable Toolpost and 6" Faceplate.
Live center and Drill Chuck
L-0 Spindle Nose, #3 morse taper in the tailstock, and 1.53" thru the spindle.
3 hp single phase motor with reversing switch. Just plug it into a 220v dryer outlet.
Hardened ways look good, and only about .003" backlash in the cross slide leadscrew.
Made in England.
The one issue it has is the power feed will advance to a point, then will need to be advanced
by hand a short distance until it catches and resumes power feed.
Come by and see it run, and I can load on a utility trailer.
Seller said it has a taper attachment, drill chuck, centers, and some cutting bits. He said the original 3phase motor has been replaced with a single phase 220, I believe 3 horse motor.
I'm wondering if this is a deal, or dud. What should I look and ask for? What should I be careful of?
From the ad:
Made in England.
