- Apr 23, 2018
- 6,560
Yeah! It's a spiral ham cutter!
(from mobile)
(from mobile)
No need to pull the engine just use the right wrench, Later models had a removable panel in the spare tire area to access the distrubutor, made it a lot easier.Fiat X-19. Pull the engine to set the timing....and just to add to the fun it was common for the distributor hold down to come loose....
Robert
Not with the right tool, it's no worse than any other shim type valve adjustment. even without the tool you can just measure all the gaps, pull the cam box off, change the shims, and bolt the cam box back on with a new gasket.Valve adjustment a pain too...
Sent from my SAMSUNG-SM-G930A using Tapatalk
No worse than any other shim setup? Maybe, but sorry, it's just a bad design and you can have that tool and still be screwed. If it's like the silly VW setup you need the goofy pliers to fish the shims out and a big box of various shims. Just like I avoid all cars with rubber bands(timing belt time bombs) I also avoid cars with valve shims.Not with the right tool, it's no worse than any other shim type valve adjustment. even without the tool you can just measure all the gaps, pull the cam box off, change the shims, and bolt the cam box back on with a new gasket.
Just finished another batch of the shim tools this morning.
At last! My heretofore futile search for a turbo encabulator is finally over!
Tom
Gibberish goes all the way back to the first standup comedic Neanderthal who got his tongue wrapped around his eye tooth and couldn't see a word he was saying , but genuine turbo encabulators are rare on craigslist. Rare indeed.I think that Stanley Unwin got there first.
Stanley Unwin (comedian) - Wikipedia
en.wikipedia.org
Kind wishes,
Nick
I had an X-19. Timing belt broke about 20,000 miles early. I pulled the head and gave it a valve job with new unbent valves and a tune up. Setting the timing didn't require removing the engine. Setting the valves required measuring the clearance and recording it then pull and measure the shims and getting the proper thickness shims from Fiat. It is a pain in the bucket seat. Installed points and set timing by removing the seat and removing an access panel behind the passenger seat. Next week on Sunday night the throwout bearing went for a spin down the street. Had to pull the suspension and transaxle that night put in a new clutch and pressure plate along with the missing bearing. That took 2 hours of hustle. It was a fun little car to drive but a constant headache to maintain.The tires never met a nail that they didn't like either. I was much younger back then.Fiat X-19. Pull the engine to set the timing....and just to add to the fun it was common for the distributor hold down to come loose....
Robert
$200 for the starter, and another $800 for the labor to tear apart the engine to replace it. (Numbers pulled out of air, I have no experience, just think it is a dumb place to put a starter. Yes, under the intake on a V6 or 8.
View attachment 290770 View attachment 290771
