- Sep 3, 2023
- 222
Some pictures of another saw accessory, and was made to be used on mills in shop too. A threaded hold down plate.
Basically found biggest piece of plate that could fit in saw vice, and drilled and tapped 1/2” and 3/8” holes in a square pattern. I usually use mill hold downs to hold parts that I need to orientate certain ways to saw. Has worked much better than a c-clamp like we used to use.
I also made holes that line up with both milling machine tables in the shop, so it can be used there to as needed. I think I’ve only used it one time on the milling machine, but nice that it can do several different jobs.
