- Oct 11, 2016
- 3,871
If you are doing barrel work on 24" barrels. you will appreciate the '40. If that and other large projects are not in your (estimated) future, then save the grand and use it for tooling later. MY 12X37 has nearly 2K in tooling (I do a wide range of work).
I upgraded from the 12" because of the screw on chuck and the belt drive. the 1236 doesn't have these limitations.
