I’m noticing this is true for most everyone. Let me restate this - am I correct in saying that the content is there but it is not showing up in search results between July 12-ish and now?
Just did a quick search and found posts that I had did on 1/21/20 so the post are there just when I look under my content page.
Nope. Mine has actually changed for the worse since I posted this morning. Now when I go to my profile and click on “postings”, the only posts that show up are from the day I introduced myself on 8/15/2013 until 10/20/2013. I'm almost sure that I’ve posted once or twice since then.I’m noticing this is true for most everyone. Let me restate this - am I correct in saying that the content is there but it is not showing up in search results between July 12-ish and now?
That's because I'm currently rebuilding the search index...apparently part of 2013 is complete! Thanks for the update!Nope. Mine has actually changed for the worse since I posted this morning. Now when I go to my profile and click on “postings”, the only posts that show up are from the day I introduced myself on 8/15/2013 until 10/20/2013. I'm almost sure that I’ve posted once or twice since then.
Tom
Better, but not there yet. If you go to my profile and look at postings, you’ll see my last post in this thread (and maybe this one) and then only one in 2019, three in 2018, one in 2017 and so on in reverse chronological order.OK everyone. Check your profile and look under postings. You should see everything at this point. Let me know if things look good from your end.
Can you check again?Better, but not there yet. If you go to my profile and look at postings, you’ll see my last post in this thread (and maybe this one) and then only one in 2019, three in 2018, one in 2017 and so on in reverse chronological order.
Tom
