Eddyde,
If the pump comes with the pulley as most do and has a tag which says to use a 3600RPM motor then that is what it is designed for. They are designed to run for x length of time then shut down; so, if you use a 1750RPM motor, you are not doing yourself any favors, . PSI is pressure per square inch meaning for every square inch of piston surface area you are dealing with that much force. If the compressor drops to 80 PSI before kicking on and your piston has 2.5 square inches to before it ever turns over it first has to overcome 200 pounds of force and that force will build as the pressure builds until it shuts off. The big heavy pulley is also a flywheel which once moving provides inertia through rotating mass to help over come that force, rotating that mass at a slower than design RPM actually creates additional load and heat. As I said in a previous post, I am not against either the 1750 nor the 3600 RPM motor, I am advocating to use the motor specification the compressor head is designed for.
