- Dec 18, 2019
- 6,464
Let's start from the beginning. Do you have enough tee-nuts for your vise? If so, you can make the tee-nuts. Or trim the extras. Use a carbide end mill in case they are hardened I was able to machine tee-nuts that were sourced from McMaster that way. My mill table slots are not uniform from slot to slot. One is narrow compared to the others. I milled the tee-nuts so they would fit that slot.
For my RT, I simply made the tee-nuts. Piece of rectangular stock. Milled the profile. Drilled the holes, tapped part way, then sawed off the individual nuts. I then cold blued them. These do not need to be hardened. Fabbed 6 in an afternoon. Blued them later. You can use them unblued.
If for a one of, you can make them out of aluminum. Actually I recommend making a prototype out of aluminum because it helps you practice what to do. You can use the aluminum tee-nuts as long as you don't abuse them by over tightening.
