The steel portion of the flange is about 2500 lbs and the brass nut inside the flange is about 500 lbs. The flange was being tapped 7/8-9 for a ring that covers the nut. The grinderstone is about 59" long and 62" in dia. It is turned at 240 RPM and is turned by a 6000 Hp motor.
