- Mar 7, 2018
- 106
I'm planning the replacement of my air compressor. I'm adding a homemade cooling system between the compressor and tank. The fan requires 110 volt. I have 220 volt at the site for the compressor motor. I really don't want to run another 110 circuit and thought I might tap into one side of the 220. Good idea? Bad idea? If it's unsafe or not advisable for other reasons I will search for a 220 fan motor for the cooling system. The compressor is outside the building under cover with the switch inside the building. Making everything run from one switch is preferred.
