- Feb 28, 2019
- 508
I guess today is the day for not so dumb questions.
I'm going to try to use taper pins for a semi-permeant assembly. So off to McMaster-Carr to spend money first!
Browsing taper pins, taper pin reamers and taper pin drill/reamers, I find that there is not one standard taper but 3 different tapers published:
Well a slope (taper) is a slope is a slope wether you measure it in furlongs or poppyseeds. That means that there are 2 different (common) slopes for taper pins:
1:50 - 1mm per 50mm, 1" in 50"
1:48 - 1/4" in 12"
1:50 == 0.020
1.48 == 0.0208
Applied to a 1" long pin, the 1:48 pin is going to be .0008 bigger at the small end. That's pretty close. Are these ment to be interchangeable? I could see that in REALLY important alignment and precision cases you would want them to be as close as possible to exact. A 1:50 pin in a 1:48 hole is going to jam on fat end first and a 1:48 in a 1:50 hole will jam on the small end first.
For a short (1" or less) hole it's pretty damn close, you are going to drive the pin in anyway. For a really long pin, only one end of the pin is going to do any of the "holding" and that could really matter depending on the application.
Fortunately, in my rush to impulse buy, I ended up with all 1:48 except for a drill/reamer combo bit (it didn't come in 1:48). Worst case I can use the drill and then ream with the 1:48 reamer I bought to open up the bottom end a tiny bit.
So that's the first question - 1:48 vs 1:50?
Second question, making the taper pin hole. It seems that the common method is to use multiple dills of successively smaller diameters and then use a reamer to get the final taper. Then there is also this drill/reamer combo I found (and bought) - seems like smarter to do the job all with one tool but now I'm not so sure.
So: drill, drill, drill and ream or drill/ream with one bit?
Pros and cons? I imagine that "reaming" action of a drill/reamer is somewhat less precise than using a dedicated reamer to finish.
Thanks,
Dave
- 1mm per 50 mm
- 1/4" in 12"
- 1" in 50"
1:48 - 1/4" in 12"
1:50 == 0.020
1.48 == 0.0208
Thanks,
Dave
