- Jul 31, 2020
- 48
I put together a Google Sheets spreadsheet to automate Tapmatic's tapping recommended speeds & feeds, RPM adjustment factors, minimum required torque & horsepower, etc.
The spreadsheet is here:
https://docs.google.com/spreadsheets/d/16MPFCAvBzhTM1Sc9MnQwcvhcceaTQ26m7MhIoyBVxJk/edit?usp=sharing
That is a shared spreadsheet that anybody with the link can use at the same time, which makes it not very useful for calculating speeds and feeds for your job.
To make a copy for yourself to use on your projects:
To use:
I welcome any feedback, especially on errors or ways to improve it.
- On the menu bar at the top, select "File"
- From the dropdown menu, select "Make a copy"
- If desired, change the name
- Select the "Make a copy" button
To use:
- Enter your choices and values in the green cells
- If the RPM cells are red due to an RPM limit, use a manually entered RPM
