- Apr 30, 2015
- 11,377
You forgot the excellent Widia/GTD taps- the gold standard, for me anyhow
Chances are they are less than ideal taps if they are sold in hardware or big box stores. Quality taps are "too" expensive for the people that go to the hardware/big box stores. The cheap taps get really expensive when you break them in a hole. If you can't use a drill press or mill, just drill a block of hardwood by hand or better on a drill press and use it to keep the drill & tap at 90 degrees. Center punch so the drill doesn't wonder off the the bar while you aren't looking. The tap you are trying to use doesn't have enough starting threads.what is your guys thoughts about Irwin taps?
That is not quite accurate. In general, the tap hole should vary with the type of material being tapped. The thread depth can vary from as low as 25% to a maximum of something a bit less than 100%. Typically, the harder the material, the lower the thread depth. Thread depths less than 50% or more than 75% are usually only for very special situations. A 5/16 drill will produce about a 75% thread depth, which is good for plastics, brass, aluminum, etc. It is a little bit small for hard materials such as mild steel, stainless steel, etc. It is probably OK for cast iron, although one might consider going to perhaps about 0.32" or so - about a P drill - if one is having trouble in cast iron.5/16" is the correct size tap drill for 3/8"-16 threads so the tap must be the culprit.
The reason everyone keeps telling you to get HSS taps and skip that carbon steel stuff is because they've learned, from experience.
Sorry about that. I knew I would miss at least 1 quality brand. Rather than work from memory I should have taken a few steps into the shop and looked in the tap cabinets. I probably have well over a hundred WIDA taps in different sizes and configurations.You forgot the excellent Widia/GTD taps- the gold standard, for me anyhow
