- May 27, 2016
- 3,469
I can already tell that I am going to lust after some sort of surface grinder. Most of what I might be interested in likely will have some parts that need it. If I just want a nice ground-looking finish on non-critical outer surfaces, I just use abrasive papers on a piece of thick glass. I know surface grinders need stiffness and vibration damping, so standing them on a floor capable of sounding through vibration may not be great, but that said, there are grinders everywhere that are on well supported wood floors.That about says it all. Except that I need a solid concrete floored shop to put a prospective grinder in.
If (when?) I do go there, and there is a problem, it would mean making holes in the floor down to concrete substrate, and using chemi-bolt fixings up to the leveling mounts. I hope to avoid games like putting microphones onto the floor, and onto the machine, and displaying the outputs together. I guess if it makes a good finish when all the other usual causes are checked out, then it's OK !
