    Dismiss Notice
[How do I?] Take this part of the quick change box apart?
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by Jmanb13, Jan 12, 2017.
  1. Jmanb13
    Jmanb13 United States Active Member Active Member
    35
    18
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    In my quest to take apart every major component of my lathe and clean it, I am now down to one of the final parts, the quick change gear box.
    BTW if you think I'm crazy for taking all this stuff apart, lets just say nothing on this lathe could be operated effectively (aka sh*t was stuck in place). You can see how gross it is in the picture below, and that is after I already cleaned it as effectively as I could before I started taking it apart. Most of this machine required me to use a screw driver to carefully scrape away hard grime before I could even tell the difference between the castings and a bolt, nut, or screw.
    Back on topic.
    I got all the gears removed but I cannot for the life of me figure out how to get the tumbler gear (21) out so that I can remove the yoke (24). The yoke sits on cylinder (30) but the tumbler gear prevents it from sliding off either end without being removed.
    I know I have to remove the shaft (23) but seeing as it is inside of a very tight space inside of the gear box, its not like I can get a hammer or punch to either side of it and actually be able to tap it.
    Anyone have any ideas on how I would remove the tumbler gear shaft (23)?
    Also fun note, pin (22) was absent. The hole is there, but the pin was either misplaced/fell out/never installed
  2. 12bolts
    12bolts Global Moderator Staff Member Active Member
    231
    63
    City:
    Hinchinbrook
    -Return to Top-
    Are you sure there isnt a piece of pin 22 still holding it together? Or perhaps someone put another pin through in a different position? It certainly looks like thats the key piece that holds it together.
    Does your shaft 23 rotate in the yoke, or does gear 21 spin on the shaft? If the shaft doesnt rotate perhaps someone has pinned it into the yoke.
    Could you get a small g clamp in there? Cut a piece of tube to provide clearance at one end for shaft 23 to slip in to and a small piece of solid at the other end to press on the shaft
    Cheers Phil
  3. Reeltor
    Reeltor United States Active User Active Member
    182
    43
    City:
    Lawrenceville
    State:
    Georgia
    -Return to Top-
    Kieth Ructer out at Vintage Machinery is bringing a LaBlond back to life.
    LeBlond Lathe Restoration - Part 5: Quick Change Gear Box Cleaning and Disassembly
    There are several videos of removal, disassembly and reassembly of the quick change gear box.
    Tozguy and Bob Korves like this.
  4. Jmanb13
    35
    18
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    23 rotates in the yoke along with the gear (21). In my inspection it doesn't look like the gear has any pins holding it in place. I can see that the taper pin hole is not in perfect alignment between the gear and the shaft, it has slipped slightly, so I do not think there is anything holding it from rotating or sliding except for friction and grime. I don't have a clamp that small, but i'll pick one up and try the tubing method. its a really tight fit, so I'm not sure if even a small clamp would be able to clear the yoke but still have clearance for the clamp screw.
    Thanks Reeltor! I have actually watched several of those videos, they have been very informative and helpful on several parts of the lathe. Unfortunately those videos are for a larger version of the leblond and the quick change gear box on the 15" is different. That one in the video is easier to take apart :)
  5. hman
    hman Active User H-M Supporter-Premium
    635
    113
    Tempe. AZ -and- Corvallis, OR
    City:
    Tempe
    State:
    Arizona
    -Return to Top-
    Hmmm ... instead of a traditional C clamp, you might be able to get a Kant Twist to work. Unlike a C clamp, the clamp screw is perpendicular to the working axis. The only downside/caution I can think of is that the Kant Twist has swiveling contact blocks, so holding everything in alignment might be a bit tricky.
    ch2co and brino like this.
  6. Jmanb13
    35
    18
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    Everyone's suggestion sparked me to think outside the box (literally). No reason to shove a tiny clamp inside the box when I can just use a big clamp and the box itself.
    mikey, RandyM, Reeltor and 2 others like this.
  7. Jmanb13
    35
    18
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    Not sure if I should start another thread, but I do have one more question.
    How the heck do you remove a pin that isn't fully through?
    Pin 38 is labeled a straight pin, thus I assume it is not tapered. The hole it is in does not go all the way through so I cannot punch it out from the backside.
  8. hman
    635
    113
    City:
    Tempe
    State:
    Arizona
    -Return to Top-
    Kudos for your success outside the box!
    As for your next question, it's kind an interesting problem. Might you able to disassemble the rest of the plunger, leaving the pin and the small shaft (37) permanently in place? If so, you could simply treat parts 24, 37 and 38 as a single unit. What I can see of the parts diagram doesn't seem to show any features on 37 that would permanently hold on to the other parts (31 thru 36).
    If you absolutely have to remove 38, you might be able to do so by drilling a smaller diameter hole from the opposite side and using some kind of drift to knock it out. By making a smaller hole, whatever feature keeps the pin from going in too deeply would still be largely there.
    brino likes this.
  9. 12bolts
    231
    63
    City:
    Hinchinbrook
    -Return to Top-
    You could drill pin #38 and maybe use an ezy-out.
    Or drill through the full length of the pin but not the hole it is in, (might be hard to gauge). Then use grease and a neat fitting punch to hydraulic it out.
    Or drill it as close as you can to the diameter and just collapse the wall.
    Or drill it oversize and replace with a larger pin.
    Cheers Phil
  10. 2volts
    2volts Australia H-M Supporter - Premium Content H-M Supporter-Premium
    157
    33
    Elsewhere, where its always fine
    City:
    Perth
    State:
    Outside US / Canada
    -Return to Top-
    pin 22 looks a similar length in the drawing.
    work out how you think pin 38 is likely to be holding what ever it is holding
    you should be able to make a good estimate of the pin length and drill the pin out.
    pete
  11. Jmanb13
    35
    18
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    I thought I might be able to disassemble the rest of the plunger based on the diagram, but I cannot for the life of me see how I can. I have looked over the entire plunger and I cannot see how it comes apart. The rest of the diagram (below) makes me think that part 32 is another pin that holds the outside of the plunger on, but I don't see it on my plunger. I think this might be one of those parts is actually "different" than what is shown. They even say that in the manual that some parts might be different.
    Thinking about how the actuation of the plunger works and the diagram, the handle 31 has to be attached to 37 somehow or else the spring would actually be pushing the plunger away instead of pulling it closer. Maybe the handle screws into 37?
    If I have to start cutting and or modifying things, I will probably just live with it. I have put the plunger and the yoke in my parts cleaner, and it seems to be moving slightly better, but I can tell its not totally clean inside because it still spits out rusty colored oil and has some drag whenever I actuate the plunger.
    This scares me as I have no idea how deep the whole goes. I might drill right through the piece that is being held in place.
  12. 2volts
    157
    33
    City:
    Perth
    State:
    Outside US / Canada
    -Return to Top-
    if you are reluctant to go further with disassembly, then persevere with putting light oil into the plunger assembly from where it passes inside 24 and repeatedly actuating the plunger, it will likely gradually loosen up.
    pete
  13. hman
    635
    113
    City:
    Tempe
    State:
    Arizona
    -Return to Top-
    Good idea, but unfortunately, Jmanb13 stated in his original post that he didn't have pin 22 :(
    I've pretty much run out of ideas by now. Jmanb13, my sincerest best wishes for figuring this one out, or for somebody here who's brilliant and/or has experience with the same lathe.
  14. Jmanb13
    35
    18
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    Thanks for the help guys! I'm just not going to worry about taking the plunger apart. With some soaking in the parts cleaner and some actuating of plunger it moves well enough for government work. It just doesn't have the smooth silkiness of movement like the rest of the things I have taken apart cleaned and reworked.
  15. 12bolts
    231
    63
    City:
    Hinchinbrook
    -Return to Top-
    Did you try unscrewing it?
  16. Jmanb13
    35
    18
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    I have not. I honestly don't see how I would grab part 37 since it only sticks out about 1/4" inside of the yoke. The only external parts that can be touched spin together as 1 piece.
  17. fitterman1
    fitterman1 Australia H-M Supporter - Premium Content H-M Supporter-Premium
    22
    8
    Australia
    City:
    Adelaide
    State:
    Outside US / Canada
    -Return to Top-
    How about polishing the larger diameter on the end of the handle with some emery or similar and looking very closely for a pin end.
  18. woochucker
    woochucker United States Active Member Active Member
    35
    18
    City:
    Pittstown
    State:
    New Jersey
    -Return to Top-
    QUOTE="Jmanb13, post: 450477, member: 43278"]In my quest to take apart every major component of my lathe and clean it, I am now down to one of the final parts, the quick change gear box.
    Back on topic.
    View attachment 143529 [/QUOTE]
    That's nothing. Looks pretty clean to me... Mine looked like this SDC11319.JPG
    And it wound up looking like this after it took a shower
Share This Page
