I'm looking for a manual for this lathe and also the specifications for the gears that fit on the output shaft on the headstock.
Can't do any threading or power feeding without those gears. According to the charts on it, it can do metric or imperial threads by switching between two different gears on the output. It has two stacked gears of different sizes on the input to the gearbox and two different coaxially mounted gears on the banjo.
The headstock output shaft has a bushing or spacer I assume is used to offset the proper gear there to mesh with either one of the banjo gears.
Dunno why anyone would remove and lose those. Must have been missing a while because someone had cobbled together a motor and belt drive to the lead screw at the tailstock end of the bed.
