- Apr 23, 2018
- 6,531
Just make sure you reverse the polarity of the magnet, because you are in the southern hemisphere.
Well it's enclosed, I don't think I can protect it more. But I got what you are trying to warn me against. Thank you.Just make sure that you place the magnet in an area where it cannot pick up steel or cast iron swarf.
Now if only I had a milling machine to use an endmill on the milling machines pulley.Use an end mill and should be a pretty good fit and minimal impact on balance
Ha, fair point. For that small of an end mill you could likely get away with a drill press if you had one of those still assembled?Now if only I had a milling machine to use an endmill on the milling machines pulley.
.......I'll make a plan.
This is not a bad plan,I think Bruce gave about the same idea in post #32. But what I don't like about it is that the sensor would sit very exposed and very close to the drawbar. So with a slip of the spanner or,and I know I would probably get some flack and rightly so,lose concentration and LEAVE the spanner on,which happened once or twice, and bang there goes the sensor. As you can see in the pic below, it would sit pretty closo to the drawbar,otherwise I would have to make a very big ring to open the distance but then it would become difficult to slide the belt over should it be necessary to do so.You can make the ring as large as the topmost pulley flange and place the magnet near the periphery,
Yoi do have a point about the pulley. It is very thin,the mag is 10mm×3mm. But so far I feel it is my best option coming from below.And if you drilled into the pulley flange, you might weaken the pulley at that point
