- Aug 5, 2015
- 237
Similar to what others have done, my Sherline lathe is mounted on 1" thick butcher-block looking wood shelf board from one of the box stores. I have the long bed version.
,... but I am also looking at other offerings with more bed clearance.
Interesting that you bring up the Taig lathe. In addition to my Sherline lathe, I have a Taig lathe that I bought used. I powered it with a treadmill motor. A nice thing about the Taig is that the accessories are quite reasonable and readily available. AND some of them will also fit the Sherline lathe. For example, I use the Taig ER-16 Collet setup on the Taig and on the Sherline.Have you looked at Taig? The clearance without riser blocks is around 4.5", if I recall correctly. It also comes with the mounting board. The prices are very reasonable as well. I liked my first one so much (purchased used) that I ended up buying another one with the power feed, and I also bought one of their milling machines. Although I have a larger lathe, the Taig is my go to; especially because, I mostly make small parts.
Thanks for all the advice. I have very limited space, and might have to use other tools, bench grinder, saws and such, so the idea of mounting to a board sounds good. That way I can swap out the tools as needed, and can still use the table/bench for other projects as well. This lathe will be my first foray into metal working, and only used for small parts, probably mostly aluminum and brass.
I am actually very concerned with the diameter of parts. When you say 1-1/4, is that the radius, so a 2.5" dia part? I assume I will have to add some riser blocks for larger parts. I have been leaning towards sherline because I want something that is usable out of the box so I can concentrate on learning how to build parts rather than how to build a lathe, but I am also looking at other offerings with more bed clearance.
It is a neat little lathe, but for what I do, the Sherline was the right choice. I can see the appeal for certain types of work. Like somebody who is doing artistic work, working more by eye than trying to hit a measurement on the dot, I think I'd rather use the Taig. ...
I'm curious for those of you who use a Taig, how do you deal with the lack of a graduated handwheel on the lead screw or is this just not an issue for you. I am now at a stage with it, where I actually like the Taig lathe, but I'm trying to figure out what niche I will find for it. Where will I go to it vs the Sherline (or Enco or Powermatic, perhaps I have a problem ).
I find the Taig lathe to be capable of extreme precision. I can hit my measurements "on the dot" as long as it does not involve the handwheel. However, I have never tried a Sherline so I am unable to make any comparison.
On the other hand, as you have stated, due to the lack of a graduated hand wheel, it is more of a go very slowly until you hit the mark matter when face cutting or other cuts where the handwheel is important; but, this has not been an issue for me. Nevertheless, I have seen on the internet various modifications by just mounting a dial caliper or a dial indictor to the lathe. I will eventually get around to doing this .
