    Dismiss Notice
Switch advise for a Logan Shaper
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by Jeff May, May 8, 2017.
  1. Jeff May
    Jeff May United States Active Member Active Member
    13
    8
    Western Maryland
    City:
    Hagerstown
    State:
    Maryland
    -Return to Top-
    I recently purchased an 8" Logan shaper. It had a 3 phase motor in it. I found a new single phase motor of the same RPM and slightly larger HP rating.
    I'd like to wire it with an Forward-Off-Reverse switch. Other than a "drum" style switch is there any other type of switches available?
    I was thinking of some type of push button style or something similar, and more compact than a drum type.
    Any thoughts or suggestions appreciated...
    Thanks,
    Jeff
  2. CluelessNewB
    CluelessNewB Active Resistor H-M Supporter-Premium
    379
    83
    United States Southern Maine
    City:
    Gorham
    State:
    Maine
    -Return to Top-
    Why would you need reverse on a metal shaper?
    A magnetic starter would be physically larger than a typical drum switch but would prevent automatic restart in case of a power failure. Imported ones run about $35 on Ebay from China.
    A manual motor starter typically has a toggle switch and would be small. There are some on Ebay for about $25. Some older Cutler Hammer motor switches have on-off push buttons, they have a art-deco style and have a bit of a cult following, prices tend to be high.
  3. Jeff May
    13
    8
    Western Maryland
    City:
    Hagerstown
    State:
    Maryland
    -Return to Top-
    Good point about reverse and restarting after a power failure.
    I wasn't sure about the reverse, I just looked at the wiring that was on it when I purchased it. It did indeed have just ON & OFF
    It had a "starter" of sorts on the back, it was pretty much shot.
    I will check out the units on ebay.
    Thanks....
  4. Silverbullet
    Silverbullet Active Member Active Member
    706
    113
    City:
    Marlton
    State:
    New Jersey
    -Return to Top-
    High Jeff, I'd put the the original switch but also have the magnetic starter for the motor. It should be usable that way with three phase motor.
  5. CluelessNewB
    379
    83
    City:
    Gorham
    State:
    Maine
    -Return to Top-
    This is the switch on my South Bend 7" shaper. It is a newer version of the Cutler-Hammer push button. Although the machine itself was in very nice condition, the previous owner didn't have a clue about electricity. The switch that came with it was a toggle switch "mounted" on the wire using electrical tape. I had this switch on hand so I used it, mostly because it looks a little bit like the original SB switch.
    Jeff, do you have any pictures of your Logan you would like to share?
  6. Jeff May
    13
    8
    Western Maryland
    City:
    Hagerstown
    State:
    Maryland
    -Return to Top-
    Here are a few of my Logan 8" on the bench. We tore it apart at the guys shop to make it easier to transport. Why I didn't take some pics of it sitting there is beyond me.
  7. Jeff May
    13
    8
    Western Maryland
    City:
    Hagerstown
    State:
    Maryland
    -Return to Top-
    Here are a few from today. I spent the weekend cleaning and prepping for paint. I was quite surprised when I got it apart. While dirty, there is hardly any wear on the machine. According to what info I have found, it was built in 1954, I think this was the 1st year Logan built a shaper... I will get some pics up when I get it together.
    20170508_141717_1494274462802.jpg 20170508_141717_1494274462802.jpg 20170508_141814_1494274501721.jpg 20170508_141814_1494274501721.jpg
    f350ca and CluelessNewB like this.
  8. Jeff May
    13
    8
    Western Maryland
    City:
    Hagerstown
    State:
    Maryland
    -Return to Top-
    Sorry for the double pics above...
  9. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,418
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    For cutting on the pull stroke, which can be a really useful idea.
  10. CluelessNewB
    379
    83
    City:
    Gorham
    State:
    Maine
    -Return to Top-
    I'm in need of some enlightenment! Can you describe a job where this would be an advantage? Thanks!
  11. Bob Korves
    3,418
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    The shaper is more rigid when it is pulling instead of pushing. It also keeps the chips much better contained. A backwards clapper box is needed for running it in reverse. Here is some great information on shapers as well as the reverse stroke overview (and an excellent channel to subscribe to!):
  12. Silverbullet
    706
    113
    City:
    Marlton
    State:
    New Jersey
    -Return to Top-
    Stevens, a sharp machinist for sure, does some nice jobs with the machines he owns. Plus he goes through everything he buys and makes it better. His gack shapers quite a machine , tons better then some of ours, but it's German right.
  13. Inflight
    Inflight United States Active User Active Member
    74
    28
    City:
    Long Beach
    State:
    California
    -Return to Top-
    On the Logan shaper, you can assemble the yoke-link to the ram two different ways. One way makes the Pull stroke faster (default), the other makes the Push stroke faster (ala Stefan Gotteswinter).
    Matt
  14. Jeff May
    13
    8
    Western Maryland
    City:
    Hagerstown
    State:
    Maryland
    -Return to Top-
    Was not aware that the yoke-link could be changed.
    I have plans for a "pull" type clapper box.
    Just another of the many projects waiting to be worked on...
    Attached are a few pics of the completed shaper... 20170523_184630_1495579729442.jpg 20170523_184552_1495579729795.jpg 20170523_184657_1495579728953.jpg
    Ulma Doctor, f350ca and hman like this.
  15. Jeff May
    13
    8
    Western Maryland
    City:
    Hagerstown
    State:
    Maryland
    -Return to Top-
    Inflight,
    I sent you a PM
  16. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    2,739
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    What a beautifully done machine, very nice work!
    :drool::drool::drool:
    Bob Korves likes this.
  17. Jeff May
    13
    8
    Western Maryland
    City:
    Hagerstown
    State:
    Maryland
    -Return to Top-
    Thank You...
    I have several other machines waiting for the same...
    I have been purchasing the last few years prior to my retirement.
    I retired at the end of May, so now it's time to get started. LOL...
    I have a Walker-Turner drill press, Delta table saw, Delta band saw, a Troyke rotary table and I'm currently putting the finishing touches on a wooden tool chest my grandfather made from plywood used to crate airplane parts in when he worked at Fairchild.
    All the above along with numerous other "projects" that are stored in tubs under my work bench.
    The past few days have been awesome working in the shop and not having to worry about the "job" LOL... IMAG2376.jpg IMAG2374.jpg 1.jpg IMAG1213.jpg
    f350ca, hman and Ulma Doctor like this.
  18. A618fan2
    A618fan2 Active Member Active Member
    69
    28
    City:
    Shippensburg
    State:
    Pennsylvania
    -Return to Top-
    Very, very nice job on the shaper - well done! The machines in the que are lucky to have you as their keeper.
    John
    Ulma Doctor likes this.
Share This Page
