U
umahunter
Forum Guest
Register Today
Well lil while back my cooler started acting up would only run 10 15 minutes and shutoff then won't turn back on for a bit and do the same so I went up and took a look one of the spider tube cracked and was dribbling on the motor so I'm sure that caused the problem any idea what I should look for besides corrosion etc to see if it can be salvaged I'm thinking something shorted or there's corrosion causing it to over heat any thoughts ???
