- Jun 7, 2013
- 10,109
My point exactly!
Sure, I will try to make it there to say hi to everybody, maybe do a little scraping.PS. Bob and John, coming to say hi when I come out there in April?
I would mount a magnetic base and a .0001" indicator on the column and practice lowering it down .0001" at a time with nothing on the chuck...say 2" above the chuck. Also grind a practice piece before doing the real thing. I suspect you will burn the part and it won't work. but you may get lucky. If I were you I would try to buy a shim the right size. Also dress the wheel fast and course, meaning take .002" and dress the wheel and then stop. don't dress the stone back and forth as this will dull the wheel and help to burn it. Also if you can run the mister wide open as the shim will get hot super fast. On the wheel, use the courses one. finish may not be the best, but the wheel and shim will stay cooler. Did you say how thick the shim was before your going to grind it?
PS. Bob and John, coming to say hi when I come out there in April? DH said he was going to come over on the 24th I think.
You plan on measuring with a depth mic ? If not ,
Little trick is to grind another object next to your good piece at the same time that can be removed . You can mic that part and not disturb your good part on the mag chuck .
We seldom take 1/2" width move-overs when you have change of throwing the part off. Who told you to do that? Move over 1/2 turn on the hand wheel or 1/8 turn and see how that goes. On most hand crank lightweight grinders I would say 1/16 to 1/8 " move over. and .0001 to .0002 down feed. A fast trick when grinding a lot off is to plunge straight down to .001or .002" to where you want to be. Mark your vertical location with a magic marker on the crank. Move up away from the part. crank over the full width of the wheel and crank it straight down again, etc. Once your done plunge move over, then dress your wheel and grind it the regular way taking 1/2 turn on the cross crank. Do a lot of experimenting before grinding the real McCoy. Oh before hand spray the washer with Dykem, so you can easily see what your doing. I found these for you: http://vintagemachinery.org/pubs/10678/18132.pdf
